はじめに
This guide will illustrate how to install a new headphone jack on an original Game Boy system. You'll need to know how to solder for this replacement, so be sure to check out iFixit's soldering technique guide.
必要な工具と部品
The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
16 の人々がこのガイドを完成させました。
