メインコンテンツにスキップ
Game Boy Display Lines/Bars
必要な工具と部品
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 手順 1、 3の画像 1 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 手順 1、 3の画像 2 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: 手順 1、 3の画像 3
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: 手順 2、 2の画像 1 Game Boy Display Lines/Bars: 手順 2、 2の画像 2
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: 手順 3、 3の画像 1 Game Boy Display Lines/Bars: 手順 3、 3の画像 2 Game Boy Display Lines/Bars: 手順 3、 3の画像 3
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: 手順 4、 1の画像 1
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mitchell
メンバー登録日: 04/03/16
184 ポイント
1ガイドが承認済み
コメント 1 件
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 44
今までの合計 4,442
