メインコンテンツにスキップ
Game Boy Color Screen Cover Replacement
必要な工具と部品
  1. Game Boy Color Screen Cover Replacement, Battery: 手順 1、 2の画像 1 Game Boy Color Screen Cover Replacement, Battery: 手順 1、 2の画像 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: 手順 2、 1の画像 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: 手順 3、 1の画像 1
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: 手順 4、 1の画像 1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
終わりに
24 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Nick Katsantones
メンバー登録日: 01/18/13
946 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G47
4 メンバー
56のガイドは作成済み
4 件のコメント
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - 返信
You only need step 7 and 8.
h027299c - 返信
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - 返信
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 193
今までの合計 22,027
