メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Removing the ribbon cable provides unhindered access to the inner workings of the Game Boy Color.
パーツ
パーツは指定されていません。
  1. Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  3. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  4. Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  5. Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  6. Push up on the tabs on either side of the ribbon with a spudger.
    • Push up on the tabs on either side of the ribbon with a spudger.
  7. Gently remove the ribbon cable from the port
    • Gently remove the ribbon cable from the port
終わりに
6 の人々がこのガイドを完成させました。
Nick Katsantones
メンバー登録日: 2013年01月18日
593 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G47
4 メンバー
36のガイドは作成済み
コメント1件
How many pins are in the ribbon?
jakebrown199 - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 112
今までの合計 5,304
