メインコンテンツにスキップ
Game Boy Color Front Housing Replacement
必要な工具と部品
  1. Game Boy Color Front Housing Replacement, Battery: 手順 1、 2の画像 1 Game Boy Color Front Housing Replacement, Battery: 手順 1、 2の画像 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Front Housing Replacement: 手順 2、 1の画像 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Front Housing Replacement, Back Housing: 手順 3、 1の画像 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Front Housing Replacement: 手順 4、 2の画像 1 Game Boy Color Front Housing Replacement: 手順 4、 2の画像 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: 手順 5、 1の画像 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Front Housing Replacement: 手順 6、 1の画像 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Front Housing Replacement, Motherboard: 手順 7、 2の画像 1 Game Boy Color Front Housing Replacement, Motherboard: 手順 7、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Front Housing Replacement: 手順 8、 1の画像 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Front Housing Replacement, Buttons: 手順 9、 1の画像 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Front Housing Replacement: 手順 10、 1の画像 1
    • Remove the original buttons from the housing.
  11. Game Boy Color Front Housing Replacement, LCD Display: 手順 11、 2の画像 1 Game Boy Color Front Housing Replacement, LCD Display: 手順 11、 2の画像 2
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
終わりに
17 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Angela Yoeurng
メンバー登録日: 01/18/13
1,662 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G47
4 メンバー
61のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 105
今までの合計 10,895
