メインコンテンツにスキップ
Game Boy Batteries Replacement
必要な工具と部品
  1. Game Boy Batteries Replacement, Batteries: 手順 1、 2の画像 1 Game Boy Batteries Replacement, Batteries: 手順 1、 2の画像 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Batteries Replacement: 手順 2、 3の画像 1 Game Boy Batteries Replacement: 手順 2、 3の画像 2 Game Boy Batteries Replacement: 手順 2、 3の画像 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Batteries Replacement: 手順 3、 2の画像 1 Game Boy Batteries Replacement: 手順 3、 2の画像 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
終わりに
25 の人々がこのガイドを完成させました。
作成者
18人の作成者と共同で作成されました。
Andrew Tramposch
メンバー登録日: 06/24/10
2,225 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S3G2
3 メンバー
34のガイドは作成済み
4 件のコメント
This was a very helpful guide. I had no idea how to replace the batteries for my GameBoy, but thanks to this amazing and helpful guide, I was able to do so. The only issue that I have with this guide is that it did not explain how to properly dispose the used batteries. I ended up soaking them in gasoline and lighting them on fire because the colors look super pretty. Don’t breath the smoke though! I’m pretty sure the smoke is toxic?
Mentat - 返信
I have struggled with this for 20 years. Thank you.
Igor Kolosha - 返信
My problem was that I removed four batteries from my Game Boy Classic but only inserted three new ones. It didn’t work. An expert told me to also insert four new ones, it worked.
Akula - 返信
Awesome! I finally know how!
Ethan Sligar - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 22
過去 30 日: 141
今までの合計 20,957
