メインコンテンツにスキップ
Game Boy Advance Shoulder Button and Side Panels Replacement
必要な工具と部品
  1. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: 手順 1、 3の画像 1 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: 手順 1、 3の画像 2 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: 手順 1、 3の画像 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: 手順 2、 2の画像 1 Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: 手順 2、 2の画像 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Back Panel: 手順 3、 1の画像 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: 手順 4、 2の画像 1 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: 手順 4、 2の画像 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Aldo Corona
メンバー登録日: 01/25/10
799 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S16G29
5 メンバー
61のガイドは作成済み
コメント 1 件
i need help th e side pannels loose
Mark - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 57
今までの合計 7,943
