はじめに
Use this repair guide to replace the screen if it has been damaged.
必要な工具と部品
ビデオの概要
Remove the back battery cover by pinching down on the tab and pulling outward.
Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
Guide does not indicate that the ribbon cable port should be UNLATCHED before attempting to remove the ribbon cable, I strongly suggest revising this as someone unfamiliar with these style of ports may assume that the ribbon cable is a compression fit and just needs to be "pulled" free of the port.
This is a terrible idea that will potentially result in tearing the ribbon! Please consider revising guide to add a step to indicate the proper method/detail for unlatching the LCD ribbon port! Thanks :)
Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
This is a BAD place to pry on a functioning LCD. I used this exact method, slowly and carefully, and my LCD shattered.
Instead, remove the lens (it’s worth it to sacrifice the lens adhesive to save your LCD), and gently and slowly press with a gloved thumb on a corner to push it through from the front of the Game Boy. Let the adhesive release itself, don’t force it. If the room is super quiet, you should be able to hear a faint peeling sound, even if you can’t see anything moving. That means you’re doing it right; just wait and it will release.
Actually you can just pry under the ribbon cable. The LCD has a metal frame there that allowed me to slowly and carefully pry from that point without (re)breaking my LCD.
Yep. Same thing just happened to me :(
18 の人々がこのガイドを完成させました。
6 件のコメント
Doesn't say where you can get new screen !!!!??
Doesn't say where to get screen from !!!??
Do this with the Game Boy Advance SP please!
Santi12008 - 返信
It does not say where you can get a new screen
criscaanca - 返信
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
To @flyingmcintosh, this happened exactly as you said it to me. Really wish I had seen your comment first but as soon as I applied the smallest bit of pressure where they outlined I heard the crunch; really frustrated with ifixit here.
