この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will give step by step instructions on how to remove and replace both speakers in a Samsung Galaxy Tab S 10.5.
必要な工具と部品
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Starting with the right speaker, remove the 10 mm Phillips #000 screws.
Use the spudger to begin pulling out the speaker.
Wedge the spudger beneath the amplifier to remove it from the adhesive holding it down.
4 の人々がこのガイドを完成させました。
3 件のコメント
Absolutely right. See my comment above. Carefully prising with the right tools between the display and the frame - the bezel - and working around the outside of the display will eventually cause the bezel to come away from the display with the back cover attached. You can then access the parts you need to get to.
