この翻訳は機械によって生成されたものであり、まだ人間による校正は行われていません。 日本語を話せますか? レビューはこちらから。
はじめに
この修理ガイドでは、Galaxy Tab S 10.5タブレットのリアカバーを取り外す手順を説明します。これは、本デバイスの内部トラブルの大半において必須となる手順です。内部の多くのコンポーネントにアクセスするには、まずリアカバーを取り外す必要があります。
必要な工具と部品
デバイスを再組み立てするには、これらのインストラクションを逆の順番に従って作業を進めてください。
21 の人々がこのガイドを完成させました。
6件のガイドコメント
This is very misleading and not the correct way to open this device. This will damage the backplate and the antennas that are glued together. The proper way to open this tablet is from the front taking the LCD out of the frame.
I disassembled and assembled back SM-T805 for motherboard replacement 2 hours ago. Discovered that back cover have a row of tiny pins with tips molded into back cover rim who are designed to break out and larger pins who will click open and back on closing just fine. Also back cover rim is glued to cover with weak glue. Seems someone Samsung decided that those larger pins alone are not enough to keep back cover firmly in place without flapping around. In reality larger pins alone on assembling will click back and keep cover in place just fine.
However I agree to you that correct way is to carefully open this tablet from screen side with these small blue flat openers or with plastic cards. It will be faster as well. Back cover rim should be removed only to replace antennas. I hope that author of these manuals will fix that.
Jamee is right, the SM-T805 (3G) can be opened separating the cover from the LCD, and not by removing that back cover that is glued to the rest.
How can I get another charging female component
peter toombs - 返信 共有
