この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In this guide, you will learn how to completely take apart a Galaxy J3 Prime and put it back together again.
A video is also available for additional help.
必要な工具と部品
ビデオの概要
Heat up the screen to loosen the adhesive.
You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
Remove the plastic bracket that will be visible when you pry up the screen.
Remove the screws on the back of the phone frame that are holding the housing of the phone together.
Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
Be gentle so you don't break anything.
Disconnect the metal flex cable from the charging port.
Remove the Motherboard from the housing.
9 の人々がこのガイドを完成させました。
3 件のコメント
great guide, this really helped
thanks for your help, this has really helped
Best guide for a J3 out there professional and easy to follow
