メインコンテンツにスキップ
Galaxy J3 Prime LCD Screen Replacement
必要な工具と部品
ビデオの概要
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
終わりに
9 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Brian Brown
メンバー登録日: 09/26/16
393 ポイント
1ガイドが承認済み
3 件のコメント
great guide, this really helped
anonymous 591 - 返信
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - 返信
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 7,095
