メインコンテンツにスキップ
GT Aggressor Pro Mountain Front Wheel Spoke Replacement
必要な工具と部品
  1. GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 手順 1、 3の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 手順 1、 3の画像 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: 手順 1、 3の画像 3
    • Placing your bike on a stand or having a friend hold the bike will make the repair easier to perform.
    • Pull the quick-release lever on the front wheel of the bike and turn it to loosen it.
  2. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 2、 2の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 2、 2の画像 2
    • Remove the quick-release lever.
  3. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 3、 2の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 3、 2の画像 2
    • Remove the fork from the axle of the wheel.
  4. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 4、 2の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 4、 2の画像 2
    • Remove the cap from the Presta air valve that is located between the spokes on the rim.
  5. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 5、 1の画像 1
    • Push up on the Presta valve to release the air in the inner tube.
  6. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 6、 2の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 6、 2の画像 2
    • Twist the valve to remove the nut from it.
  7. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 7、 3の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 7、 3の画像 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 7、 3の画像 3
    • Remove the tire and inner tube from the rim.
    • It is possible to do this with your hands but using a tire lever would simplify the process.
  8. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 8、 3の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 8、 3の画像 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 8、 3の画像 3
    • Loosen the spoke by using the spoke wrench.
    • Use a flat head screwdriver to remove the screw corresponding to the damaged or broken spoke.
  9. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 9、 1の画像 1
    • Use a T25 screwdriver to remove the six 10.0 mm screws from the disk brake rotor.
  10. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 10、 2の画像 1 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 10、 2の画像 2
    • Unthread and remove the spoke from the rim and the hub.
    • Make sure to look at the alignment of the spoke removed in order to put the new spoke back on the same way.
    • The spoke will come out of the hole.
  11. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: 手順 11、 1の画像 1
    • Thread the new spoke into the rim.
    • Make sure the alignment/placement of the new spoke is the same as the old one.
終わりに
Thank you for using our guide. Enjoy getting back on the trails or roads!
作成者
3人の作成者と共同で作成されました。
Ronaldo Pascual
メンバー登録日: 02/10/23
193 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 2-17, Cameron Spring 2023 University of Memphis, Team 2-17, Cameron Spring 2023人のメンバー
UM-CAMERON-S23S2G17
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 33
今までの合計 886
