メインコンテンツにスキップ
GK61 Keyboard Keycap/Switch Replacement
必要な工具と部品
  1. GK61 Keyboard Keycap/Switch Replacement, Keycap/Switches: 手順 1、 1の画像 1
    • Unplug the keyboard.
    • When the keyboard lights are off, it indicates that the keyboard is turned off.
  2. GK61 Keyboard Keycap/Switch Replacement: 手順 2、 3の画像 1 GK61 Keyboard Keycap/Switch Replacement: 手順 2、 3の画像 2 GK61 Keyboard Keycap/Switch Replacement: 手順 2、 3の画像 3
    • Use a keycap puller to remove the top and bottom of the keycaps from the keyboard.
    • When pulling the keycap, make sure to apply pressure until you hear a click sound from the keycap.
    • Remember when using a keycap puller, place it on a key in a vertical position.
  3. GK61 Keyboard Keycap/Switch Replacement: 手順 3、 1の画像 1
    • After removing all the keycaps, put it in a bowl.
    • You can either use alcohol wipes or water to clean your keycaps.
  4. GK61 Keyboard Keycap/Switch Replacement: 手順 4、 1の画像 1
    • Dry the keycaps on a rag or paper towel.
    • Remember to let your keycaps dry for about 5-10 minutes after cleaning.
  5. GK61 Keyboard Keycap/Switch Replacement: 手順 5、 1の画像 1
    • Using a hand held vacuum cleaner remove any excess dust, hair, and oils.
    • Tilting your keyboard will also help for a deeper clean
    • If you cannot locate a hand held vacuum cleaner, a compressed air duster will also work.
  6. GK61 Keyboard Keycap/Switch Replacement: 手順 6、 3の画像 1 GK61 Keyboard Keycap/Switch Replacement: 手順 6、 3の画像 2 GK61 Keyboard Keycap/Switch Replacement: 手順 6、 3の画像 3
    • Using a Q-Tip with rubbing alcohol, gently clean and rub the crevices around the plate of the keyboard.
    • Make sure not to pour rubbing alcohol onto your keyboard. Doing so may cause severe damage to the keyboard.
  7. GK61 Keyboard Keycap/Switch Replacement: 手順 7、 3の画像 1 GK61 Keyboard Keycap/Switch Replacement: 手順 7、 3の画像 2 GK61 Keyboard Keycap/Switch Replacement: 手順 7、 3の画像 3
    • Using a switch puller, pull the keyboard switch from the top and bottom of the switch.
    • Remember to always pull straight up to fully remove the switch.
  8. GK61 Keyboard Keycap/Switch Replacement: 手順 8、 2の画像 1 GK61 Keyboard Keycap/Switch Replacement: 手順 8、 2の画像 2
    • Grab a replacement switch to replace the broken switch.
    • Push the switch straight down into the socket of the switch.
    • To avoid any damages, make sure to always push straight down and not in any other direction.
  9. GK61 Keyboard Keycap/Switch Replacement: 手順 9、 3の画像 1 GK61 Keyboard Keycap/Switch Replacement: 手順 9、 3の画像 2 GK61 Keyboard Keycap/Switch Replacement: 手順 9、 3の画像 3
    • After drying the keycaps, put the keycaps back into their sockets.
    • Align the keycap with the socket of the switch and push straight down with a bit of pressure.
    • When pushing straight down, you will hear a click sound that will indicate that the keycap has been placed.
終わりに
作成者
1人の作成者と共同作成されました。
Alexander Truong
メンバー登録日: 05/05/21
169 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G28, O'Regan Summer 2021 York University, Team S1-G28, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G28
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 40
今までの合計 1,533
