はじめに
This guide can help you replace the alarm light board (PWA), part M1227419-S), for your GE Carescape R860.
If the alarm light is malfunctioning, replacing the PWA board may be necessary. To get access to the PWA board, one must first remove the rear housing and shield of the display unit. For instructions on removal, refer to the Display Unit Disassembly.
For additional information regarding the replacement of the alarm light board (PWA), see section 9.5.3 (pg. 251) of the GE CARESCAPE R860 Technical Reference Manual.
必要な工具と部品
Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
