メインコンテンツにスキップ
GATEWAY ML6720 Keyboard Replacement
必要な工具と部品
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: 手順 2、 1の画像 1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: 手順 3、 2の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 3、 2の画像 2
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: 手順 4、 2の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 4、 2の画像 2
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: 手順 5、 2の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 5、 2の画像 2
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: 手順 6、 1の画像 1
    • Turn the laptop on its backside with the stickers and barcode facing you.
  6. GATEWAY ML6720 Keyboard Replacement: 手順 7、 3の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 7、 3の画像 2 GATEWAY ML6720 Keyboard Replacement: 手順 7、 3の画像 3
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  7. GATEWAY ML6720 Keyboard Replacement: 手順 8、 1の画像 1
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  8. GATEWAY ML6720 Keyboard Replacement: 手順 9、 2の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover
  9. GATEWAY ML6720 Keyboard Replacement: 手順 10、 2の画像 1 GATEWAY ML6720 Keyboard Replacement: 手順 10、 2の画像 2
    • Pull up the keyboard with your finger
終わりに
作成者
5人の作成者と共同で作成されました。
Nathan Da Silva
メンバー登録日: 10/19/16
401 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S2G3
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 11
今までの合計 543
