メインコンテンツにスキップ
G'z One Boulder Front Logic Board Replacement
必要な工具と部品
  1. G'z One Boulder Front Logic Board Replacement, Inside Screen Cover: 手順 1、 1の画像 1
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
  2. G'z One Boulder Front Logic Board Replacement: 手順 2、 2の画像 1 G'z One Boulder Front Logic Board Replacement: 手順 2、 2の画像 2
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  3. G'z One Boulder Front Logic Board Replacement: 手順 3、 2の画像 1 G'z One Boulder Front Logic Board Replacement: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
  4. G'z One Boulder Front Logic Board Replacement: 手順 4、 2の画像 1 G'z One Boulder Front Logic Board Replacement: 手順 4、 2の画像 2
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  5. G'z One Boulder Front Logic Board Replacement, Front Logic Board: 手順 5、 3の画像 1 G'z One Boulder Front Logic Board Replacement, Front Logic Board: 手順 5、 3の画像 2 G'z One Boulder Front Logic Board Replacement, Front Logic Board: 手順 5、 3の画像 3
    • Remove one screw located on the left side of the phone with the pictured orientation in mind.
    • This will release the logic board from the back case.
    • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
  6. G'z One Boulder Front Logic Board Replacement: 手順 6、 3の画像 1 G'z One Boulder Front Logic Board Replacement: 手順 6、 3の画像 2 G'z One Boulder Front Logic Board Replacement: 手順 6、 3の画像 3
    • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
    • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
    • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
終わりに
作成者
3人の作成者と共同で作成されました。
Raymond Caulder
メンバー登録日: 03/11/13
22 ポイント
3のガイドは作成済み
チーム
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S13G3
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 775
