メインコンテンツにスキップ
Fujtsu Lifebook Model A6110 Disk Drive Replacement
必要な工具と部品
  1. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 手順 1、 2の画像 1 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 手順 1、 2の画像 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 手順 2、 1の画像 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 手順 3、 3の画像 1 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 手順 3、 3の画像 2 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 手順 3、 3の画像 3
    • The disk drive will be located on the side of the computer, on the top-left corner
    • Using a Phillips #1 screwdriver, remove the two 6 mm screws which are located above the disk drive. Remove the screws by turning your screwdriver counter-clockwise.
  4. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 手順 4、 2の画像 1 Fujtsu Lifebook Model A6110 Disk Drive Replacement: 手順 4、 2の画像 2
    • Insert the metal spudger in the gap between the disk drive and the laptop's body itself, as seen in the picture.
    • Push the spudger down, so that it is behind the drive.
    • Gently pull the disk drive out from the laptop until it unlatches.
  5. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 手順 5、 1の画像 1
    • Once the disk-drive has been unlatched from its slot, pull it gently from the laptop case.
終わりに
作成者
3人の作成者と共同で作成されました。
Cody Moniz
メンバー登録日: 10/19/16
416 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S3G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 426
