必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
With battery removed take out the fan dust catcher (indicated by the red rectangle).
Using PH1 Philips screwdriver bit (indicated in third picture) remove the screws identified by the red circles.
Remove the RAM, fan, and hard drive covers.
Remove the hard drive. Now everything should look like picture two.
この手順は未翻訳です。 翻訳を手伝う。
Next we are going to remove the keyboard top, this gives access to the inside of the laptop.
There are three tabs on the keyboard cover that keep it attached. (indicated by picture one)
Picture two you can see them disconnected, using a finger nail or electronic case opener gently release the tab by applying outward force on the black plastic part of the case.
この手順は未翻訳です。 翻訳を手伝う。
After disconnecting the display connections we are ready to unscrew the display mount screws.
Use the trusty PH1 bit to take out the 4 screws indicated in picture one.
You can now lift out the display assembly, 2 antennas and 3 cables will be attached to it. Set it aside.
4 件のコメント
Thanks for posting this..
Thank you! Very helpful
Well done! Thank you!
