必要な工具と部品
Remove battery by pushing down the latch lock and sliding the latch to the left as shown.
With your finger nail pry the battery off at the indent for the latch lock.
With battery removed take out the fan dust catcher (indicated by the red rectangle).
Using PH1 Philips screwdriver bit (indicated in third picture) remove the screws identified by the red circles.
Remove the RAM, fan, and hard drive covers.
Remove the hard drive. Now everything should look like picture two.
Next we are going to remove the keyboard top, this gives access to the inside of the laptop.
There are three tabs on the keyboard cover that keep it attached. (indicated by picture one)
Picture two you can see them disconnected, using a finger nail or electronic case opener gently release the tab by applying outward force on the black plastic part of the case.
Remove the wifi antennas. (picture one)
Remove the display, touch, and backlight connectors from the motherboard as indicated in pictures two and three.
Remove the 9 screws indicated in picture 1 with PH1 bit.
Pivot the motherboard up from the front as indicated in picture 2.
Heatsink is very inadequate, which is why this laptop gets noticeably high temperatures.
4 件のコメント
Thanks for posting this..
Thank you! Very helpful
Well done! Thank you!
