パーツ
パーツは指定されていません。
  1. Turn the laptop over so that the bottom of the laptop faces you.
    • Turn the laptop over so that the bottom of the laptop faces you.
  2. Locate the hard drive cover and remove the screw. Locate the hard drive cover and remove the screw.
    • Locate the hard drive cover and remove the screw.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Now you can use your finger to pull the cover off. Now you can use your finger to pull the cover off.
    • Now you can use your finger to pull the cover off.
  5. Pull on the pull tab to release the hard drive. Now you can take the hard drive out of the laptop. Now you can take the hard drive out of the laptop.
    • Pull on the pull tab to release the hard drive.
    • Now you can take the hard drive out of the laptop.
  6. There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws. Do not take the screws out of the hard drive itself, only from the bracket. With the screws removed the drive slides out of the bracket.
    • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
    • Do not take the screws out of the hard drive itself, only from the bracket.
    • With the screws removed the drive slides out of the bracket.
    • Now you can replace the hard drive with a new one.
まとめ
3 の人々がこのガイドを完成させました。
storm
メンバー登録日: 2012年07月07日
506 ポイント
2のガイドは作成済み
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - 返信
Is it a Windows password or a BIOS password?
storm -
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 3,478
