はじめに
A repair manual for the Fujitsu Siemens Amilo Pro 2010 and 2020 and 2030 which shows you how to replace the keyboard!
  1. Remove AC adapter and battery.
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Use a flat head screwdriver to pry out the hinge cover.
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Remove the one screw holding in the keyboard.
    • Remove the one screw holding in the keyboard.
  5. Pull the keyboard up towards you.
    • Pull the keyboard up towards you.
  6. Pull the ribbon cable and the keyboard will come out.
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
まとめ
ある他の人がこのガイドを完成しました。
Jeremy Scalpello
メンバー登録日: 2010年04月25日
298 ポイント
1ガイドが承認済み
コメント1件
try to focus the image while taking the picture so people can understand better were to touch
storm builder - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 14,344
