メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
必要な工具と部品
  1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: 手順 1、 1の画像 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 2、 1の画像 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 3、 1の画像 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: 手順 4、 1の画像 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 5、 1の画像 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 6、 1の画像 1
  7. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 7、 1の画像 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: 手順 8、 1の画像 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 9、 1の画像 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 10、 1の画像 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 11、 1の画像 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: 手順 12、 1の画像 1
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 13、 1の画像 1
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 14、 1の画像 1
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 15、 1の画像 1
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 16、 3の画像 1 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 16、 3の画像 2 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 16、 3の画像 3
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 手順 17、 1の画像 1
    • Remove the connector with an ESD-safe spudger.
  18. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: 手順 18、 1の画像 1
    • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
    • Gently separate the MicroSD card from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Casey
メンバー登録日: 03/25/19
283 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019人のメンバー
IUPUI-HENNING-S19S1G1
3 メンバー
3のガイドは作成済み
1件のガイドコメント
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 43
今までの合計 776
