メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
必要な工具と部品
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: 手順 1、 1の画像 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: 手順 4、 1の画像 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 5、 1の画像 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 6、 1の画像 1
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 7、 1の画像 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: 手順 8、 1の画像 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 9、 1の画像 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 10、 1の画像 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 11、 1の画像 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: 手順 12、 1の画像 1
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 13、 1の画像 1
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 14、 1の画像 1
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 15、 2の画像 1 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 15、 2の画像 2
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 16、 2の画像 1 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 手順 16、 2の画像 2
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Briana Cockerham
メンバー登録日: 03/26/19
151 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019人のメンバー
IUPUI-HENNING-S19S1G1
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 18
今までの合計 692
