メインコンテンツにスキップ
Fujitsu Lifebook S6120 Motherboard Replacement
必要な工具と部品
  1. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 手順 1、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 手順 1、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: 手順 2、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: 手順 2、 2の画像 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 3、 1の画像 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 4、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 4、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 4、 3の画像 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 5、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 5、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 5、 3の画像 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 手順 6、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 手順 6、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: 手順 6、 3の画像 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 7、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 7、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 7、 3の画像 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: 手順 8、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: 手順 8、 2の画像 2
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  9. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 9、 1の画像 1
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  10. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 10、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the ribbon from the motherboard with a pair of tweezers.
  11. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 11、 3の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 11、 3の画像 2 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 11、 3の画像 3
    • Use a 5mm nut driver to unscrew the nuts.
  12. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 12、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 12、 2の画像 2
    • Pull the ribbon tab up and off the motherboard.
  13. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 13、 1の画像 1
    • Remove the metal plate covering the motherboard.
  14. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 14、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 14、 2の画像 2
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  15. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 15、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 15、 2の画像 2
    • Pinch your fingers around the base of the connector and pull it out.
  16. Fujitsu Lifebook S6120 Motherboard Replacement: 手順 16、 2の画像 1 Fujitsu Lifebook S6120 Motherboard Replacement: 手順 16、 2の画像 2
    • Lift the motherboard off the plastic base.
終わりに
作成者
2人の作成者と共同で作成されました。
Jessi Gallant
メンバー登録日: 03/19/18
899 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S5G5
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 9
今までの合計 999
