The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
Lift the hinge cover enough to expose the ribbon cable.
The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
Lift the keyboard enough to expose the ribbon cable.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
