メインコンテンツにスキップ
Fujitsu LifeBook N3510 Keyboard Replacement
必要な工具と部品
  1. Fujitsu LifeBook N3510 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 2、 1の画像 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: 手順 3、 3の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: 手順 3、 3の画像 2 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: 手順 3、 3の画像 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 4、 1の画像 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 5、 3の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 5、 3の画像 2 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 5、 3の画像 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 6、 2の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 6、 2の画像 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 7、 2の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 7、 2の画像 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: 手順 8、 3の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: 手順 8、 3の画像 2 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: 手順 8、 3の画像 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 9、 2の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 9、 2の画像 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Keyboard Replacement: 手順 10、 2の画像 1 Fujitsu LifeBook N3510 Keyboard Replacement: 手順 10、 2の画像 2
    • After the ribbon has been detached, carefully remove the keyboard.
終わりに
作成者
8人の作成者と共同で作成されました。
Neil Daniels
メンバー登録日: 01/17/11
1,411 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G18
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 6,009
