メインコンテンツにスキップ
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
必要な工具と部品
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 2、 1の画像 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 3、 1の画像 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 手順 4、 3の画像 1 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 手順 4、 3の画像 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: 手順 4、 3の画像 3
    • Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 1 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 2
    • On the bottom of the laptop, find the bottom-plate screw holes. They are located near the disc drive. Parallel to them is a 2.4mm screw.
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew.
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 6、 2の画像 1 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 6、 2の画像 2
    • Flip the laptop over and open it facing you.
    • Use a spudger to lift the bottom black cover on both sides.
    • The cover is connected to an aluminum strip, so be careful lifting it.
    • For the proceeding steps, put on an anti-static wrist strap and clip it to something metal. Ensure that it's clipped to a grounded metal in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 7、 3の画像 1 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 7、 3の画像 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 7、 3の画像 3
    • Once the black cover is lifted, flip it and set it on the keyboard.
    • Locate the hardware disc on the right side and gently lift it out. Place it on the side of the laptop.
    • The hard drive is connected with a strip, so be careful when lifting it out.
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 8、 3の画像 1 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 8、 3の画像 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: 手順 8、 3の画像 3
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and use a spudger, preferably a wider one, to remove the black pin holder on the side where it touches the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until the holder comes off.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Nicholas Ross
メンバー登録日: 01/20/12
174 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-31, Amido Winter 2012 Cal Poly, Team 10-31, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G31
5 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 30
今までの合計 5,275
