メインコンテンツにスキップ
はじめに
Replacing the hard drive for the Fujitsu Lifebook U810 can be a simple process if directions are followed carefully. The only tool required is a Phillips head +J0 sized screwdriver to remove the Phillips screws on the back of the LifeBook. This guide improves the memory and speed of the device. You can find a new hard drive online by searching the model number and corresponding part for the U810 model.
パーツ
パーツは指定されていません。
  1. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. Remove the two 5mm screws with a Phillips #0 screwdriver. Remove the hard drive from the LifeBook. Remove the hard drive from the LifeBook.
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the hard drive from the LifeBook.
  3. Detach the two wires connected to the hard drive by gently pulling them out of place. Detach the two wires connected to the hard drive by gently pulling them out of place.
    • Detach the two wires connected to the hard drive by gently pulling them out of place.
終わりに
Anne Kutt
メンバー登録日: 2018年10月22日
197 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S4-G7, Lore Fall 2018 UC Davis, Team S4-G7, Lore Fall 2018人のメンバー
UCD-LORE-F18S4G7
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 124
