メインコンテンツにスキップ
Fujifilm XP20 Rear Case Replacement
必要な工具と部品
  1. Fujifilm XP20 Rear Case Replacement, Rear Case: 手順 1、 3の画像 1 Fujifilm XP20 Rear Case Replacement, Rear Case: 手順 1、 3の画像 2 Fujifilm XP20 Rear Case Replacement, Rear Case: 手順 1、 3の画像 3
    • Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm XP20 Rear Case Replacement: 手順 2、 3の画像 1 Fujifilm XP20 Rear Case Replacement: 手順 2、 3の画像 2 Fujifilm XP20 Rear Case Replacement: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screws on the bottom of the camera closer to the back.
    • Using a Phillips #00 screwdriver remove the two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm XP20 Rear Case Replacement: 手順 3、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm XP20 Rear Case Replacement: 手順 4、 3の画像 1 Fujifilm XP20 Rear Case Replacement: 手順 4、 3の画像 2 Fujifilm XP20 Rear Case Replacement: 手順 4、 3の画像 3
    • Using a 1.5mm Hex screwdriver, remove the 3.0 mm hex screw on top edge of silver panel.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm XP20 Rear Case Replacement: 手順 5、 3の画像 1 Fujifilm XP20 Rear Case Replacement: 手順 5、 3の画像 2 Fujifilm XP20 Rear Case Replacement: 手順 5、 3の画像 3
    • Unlatch the four clasps located on each side of the camera by hand.
    • The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm XP20 Battery Replacement for instructions.
  6. Fujifilm XP20 Rear Case Replacement: 手順 6、 3の画像 1 Fujifilm XP20 Rear Case Replacement: 手順 6、 3の画像 2 Fujifilm XP20 Rear Case Replacement: 手順 6、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
終わりに
作成者
2人の作成者と共同で作成されました。
Stephen Harden
メンバー登録日: 10/08/16
243 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 1-1, Wilson Fall 2016 IUPUI, Team 1-1, Wilson Fall 2016人のメンバー
IUPUI-WILSON-F16S1G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 585
