メインコンテンツにスキップ
はじめに
This guide will show you how to properly replace the FuijFilm XP20 battery.
  1. To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open. To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open. To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open.
    • To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open.
  2. Now that the hatch is open, you should be able to  see the battery.  To take out the old battery, just push down on it and then it will slightly eject itself, making it possible for you to grab with your finger tips.
    • Now that the hatch is open, you should be able to see the battery. To take out the old battery, just push down on it and then it will slightly eject itself, making it possible for you to grab with your finger tips.
    • At this point, this battery cannot be used again, be sure to dispose of it in a proper manner.
終わりに
Craig Swartz
メンバー登録日: 2016年10月08日
101 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-1, Wilson Fall 2016 IUPUI, Team 1-1, Wilson Fall 2016人のメンバー
IUPUI-WILSON-F16S1G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 452
