この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Follow these steps to replace the motherboard. The motherboard should only be replaced after other troubleshooting steps have been attempted.
必要な工具と部品
Slide the small black tab on the bottom of the camera to the left to unlock the battery cover.
この手順で使用する道具:Mako Driver Kit - 64 Precision Bits$39.95
This is a camera produced by a Japanese camera manufacturer. The Japanese camera industry loves using JIS (Japanese Industrial Standard) screws.
Don't be tempted by your Phillips screw driver collection. Although PH#00 will interchange with JIS#00, it is not a perfect fit. Using Phillips will cause more wear on the head of the JIS screws and cause the screws to prematurely strip.
Have both JIS#00 and JIS#000 screw drivers available for this teardown. Luckily, both bits are included in the ifixit 64bit kit.
Get your picks ready!
To get any deeper into this camera, the right-hand port cover assembly must be removed first. Once this is removed, you will have access to the screws that secure the other components.
There's a tiny hole toward the bottom right of the battery compartment. Using the pick tool, press into that hole.
A plastic rod will release. That plastic rod is the axis the hinge rotates about.
Fuji! What did we tell you about hiding screws behind closed doors! That's pretty under the table Fuji. Don't do it again. Promise?
The devil's in the details with this camera. Slide the port cover off the hinge rod.
Using a pair of pliers, pull the rod out of the top plate of the camera. Now you'll finally have access to all the screws that need to be removed.
Once the electronics are exposed, it is highly recommended that you remain ESD safe. ESD can fry your precious electronics, and pass thousands of volts through components only rated for a few V DC. ESD can sure ruin your day if you are not careful.
Use an ESD mat and wrist strap, and make sure you are grounded for the remaining of the teardown. Make sure your ESD mat is connected to the ground of a nearby outlet, and make sure your house actually has a ground. Consult an electrician if you are unsure.
Once the lens has been taken off, flip the camera over and unscrew the two 4.0 mm screws on the front of the camera, next to the lens cover.
2 の人々がこのガイドを完成させました。
2 件のコメント
Thank you for this. Such a valuable resource. Where can i get a replacement motherboard for this camera
This was a great guide for me to dissemble my Fuji X100S, to remove the Motherboard and replace F401 fuse. I was able to follow your clear instructions, particularly with all of the photos. Thank you very much.
