はじめに
The camera shell is the plastic casing that makes up the outside of the Fujifilm Instax Mini 8; which is meant to hide wires, protect the film, and hold the main components of this camera together in a compact manner. A damaged shell will compromise the integrity of the device and may cause other parts of the camera to malfunction.
必要な工具と部品
Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
12 の人々がこのガイドを完成させました。
18 件のコメント
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
but where near the exit? i cannot find it
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - 返信
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
