メインコンテンツにスキップ
Fujifilm Finepix S1800 Top Cover Replacement
必要な工具と部品
  1. Fujifilm Finepix S1800 Top Cover Replacement, Back Cover Assembly: 手順 1、 1の画像 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Top Cover Replacement: 手順 2、 1の画像 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Top Cover Replacement: 手順 3、 1の画像 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Top Cover Replacement: 手順 4、 2の画像 1 Fujifilm Finepix S1800 Top Cover Replacement: 手順 4、 2の画像 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: 手順 5、 2の画像 1 Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: 手順 5、 2の画像 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Top Cover Replacement: 手順 6、 1の画像 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Top Cover Replacement: 手順 7、 1の画像 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Top Cover Replacement, Top Cover: 手順 8、 1の画像 1
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Top Cover Replacement: 手順 9、 2の画像 1 Fujifilm Finepix S1800 Top Cover Replacement: 手順 9、 2の画像 2
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Top Cover Replacement: 手順 10、 2の画像 1 Fujifilm Finepix S1800 Top Cover Replacement: 手順 10、 2の画像 2
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Top Cover Replacement: 手順 11、 1の画像 1
    • Remove the top cover.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Ryan Rockford
メンバー登録日: 02/15/17
618 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G6
4 メンバー
10のガイドは作成済み
コメント 1 件
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
Bob Wilkins - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 649
