メインコンテンツにスキップ
Fujifilm Finepix S1000fd Display Screen Replacement
必要な工具と部品
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: 手順 1、 2の画像 1 Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: 手順 1、 2の画像 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 2、 2の画像 1 Fujifilm Finepix S1000fd Display Screen Replacement: 手順 2、 2の画像 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 3、 1の画像 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: 手順 4、 1の画像 1
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 5、 1の画像 1
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 6、 1の画像 1
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 7、 1の画像 1
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: 手順 8、 1の画像 1
    • Lift up the gray component where the display screen use to sit in.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Lizzie Eller
メンバー登録日: 01/25/17
422 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G7
4 メンバー
10のガイドは作成済み
コメント 1 件
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 930
