メインコンテンツにスキップ
Fujifilm Finepix F10 6.3 MP Lens Replacement
必要な工具と部品
  1. Fujifilm Finepix F10 6.3 MP Lens Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 2、 1の画像 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 3、 1の画像 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 4、 3の画像 1 Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 4、 3の画像 2 Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 4、 3の画像 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Replacement, Front cover: 手順 5、 1の画像 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 6、 1の画像 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 7、 2の画像 1 Fujifilm Finepix F10 6.3 MP Lens Replacement: 手順 7、 2の画像 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: 手順 8、 3の画像 1 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: 手順 8、 3の画像 2 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: 手順 8、 3の画像 3
    • Firmly grasp the lens and pull completely from housing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sarah Looper
メンバー登録日: 03/11/13
100 ポイント
7のガイドは作成済み
チーム
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S13G4
2 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,701
