メインコンテンツにスキップ
Fujifilm FinePix Z90 LCD Screen Replacement
必要な工具と部品
  1. Fujifilm FinePix Z90 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 1 Fujifilm FinePix Z90 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 2
    • Locate the right side of the camera, where the USB connector is. Remove uncovered Phillips #000 screw.
    • Once the uncovered screw is removed, open the USB connector cover to remove the next Phillips #000 screw.
  2. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 2、 2の画像 1 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove the two uncovered Phillips #000 screws from the left side.
    • Repeat for the screws on the bottom.
  3. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 3、 3の画像 1 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 3、 3の画像 2 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 3、 3の画像 3
    • Remove the casing from the back of camera where LCD screen is located.
    • On the right side of the camera locate the wrist strap. Carefully remove the lace that attached wrist strap to camera.
    • Located just above (or next to) lace that attaches wrist strap is a ribbon cable. Be extremely cautious not to tear when removing lace. This ribbon connects the front panel to the motherboard.
    • Gently remove silver piece that lace was connected to, set aside.
  4. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 4、 2の画像 1 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 4、 2の画像 2
    • After removing silver piece that attached to lace, locate and remove screw.
    • Turning camera back to the LCD screen, remove the three screws just to the right of screen. These are located next to the ribbon cables attaching the LCD to the motherboard.
  5. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 5、 1の画像 1
    • Gently remove front of camera face (casing).
    • Once removed motherboard should be displayed. Be very careful with this section.
  6. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 6、 1の画像 1
    • Using a plastic opening tool, pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is another ribbon cable attaching the LCD screen to the motherboard; be careful not to tear it. Be sure to tear black electrical tape before removing ribbon.
  7. Fujifilm FinePix Z90 LCD Screen Replacement: 手順 7、 3の画像 1 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 7、 3の画像 2 Fujifilm FinePix Z90 LCD Screen Replacement: 手順 7、 3の画像 3
    • Using a plastic opening tool, flip open the black lever to release the ribbon.
    • Gently slide the cable out of the lock; the LCD screen is now ready to be removed.
終わりに
Once you have removed the damaged screen, following the instructions in reverse order will instruct you to reassemble your device.
作成者
3人の作成者と共同で作成されました。
Sam Clark
メンバー登録日: 11/03/15
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 UMass Dartmouth, Team 1-6, Bhusal Fall 2015人のメンバー
UMASSD-BHUSAL-F15S1G6
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 22
今までの合計 948
