メインコンテンツにスキップ
Fujifilm FinePix Z5 Motherboard Replacement
必要な工具と部品
  1. Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Motherboard Replacement: 手順 2、 2の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Motherboard Replacement: 手順 3、 3の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 3、 3の画像 2 Fujifilm FinePix Z5 Motherboard Replacement: 手順 3、 3の画像 3
    • Remove the back of the camera by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Motherboard Replacement: 手順 4、 2の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 4、 2の画像 2
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Motherboard Replacement: 手順 5、 2の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 5、 2の画像 2
    • Using a plastic opening tool, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Motherboard Replacement: 手順 6、 3の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 6、 3の画像 2 Fujifilm FinePix Z5 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold ribbon cable which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw on the right side which is anchoring the motherboard.
  7. Fujifilm FinePix Z5 Motherboard Replacement: 手順 7、 3の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 7、 3の画像 2 Fujifilm FinePix Z5 Motherboard Replacement: 手順 7、 3の画像 3
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Motherboard Replacement: 手順 8、 3の画像 1 Fujifilm FinePix Z5 Motherboard Replacement: 手順 8、 3の画像 2 Fujifilm FinePix Z5 Motherboard Replacement: 手順 8、 3の画像 3
    • Hold wires on the left with an index finger.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Lauren Gibbs
メンバー登録日: 02/10/12
1 ポイント
1ガイドが承認済み
チーム
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012人のメンバー
JMU-KLEIN-S12S3G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 652
