はじめに
Use this guide to replace a broken or malfunctioning lens on your Fujifilm FinePix XP80 camera.
必要な工具と部品
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Using the H1.3 hex head bit, remove the four screws on the front of the camera.
もう少しです!
終わりに
