メインコンテンツにスキップ
Fujifilm FinePix XP80 Lens Replacement
必要な工具と部品
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: 手順 1、 3の画像 1 Fujifilm FinePix XP80 Lens Replacement, Battery: 手順 1、 3の画像 2 Fujifilm FinePix XP80 Lens Replacement, Battery: 手順 1、 3の画像 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: 手順 2、 1の画像 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: 手順 3、 1の画像 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: 手順 4、 1の画像 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: 手順 5、 1の画像 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: 手順 6、 1の画像 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: 手順 7、 1の画像 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: 手順 8、 1の画像 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: 手順 9、 2の画像 1 Fujifilm FinePix XP80 Lens Replacement: 手順 9、 2の画像 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: 手順 10、 1の画像 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: 手順 11、 1の画像 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: 手順 12、 1の画像 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: 手順 13、 3の画像 1 Fujifilm FinePix XP80 Lens Replacement: 手順 13、 3の画像 2 Fujifilm FinePix XP80 Lens Replacement: 手順 13、 3の画像 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: 手順 14、 1の画像 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: 手順 15、 1の画像 1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
終わりに
作成者
5人の作成者と共同で作成されました。
Amanda Lewis
メンバー登録日: 09/25/16
317 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G3
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 1,546
