メインコンテンツにスキップ
Fujifilm FinePix XP70 Front and Back Panel Replacement
必要な工具と部品
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: 手順 1、 1の画像 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 2、 2の画像 1 Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 2、 2の画像 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 3、 1の画像 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: 手順 4、 1の画像 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 5、 1の画像 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 6、 1の画像 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 7、 1の画像 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 8、 2の画像 1 Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 8、 2の画像 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 9、 1の画像 1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 10、 3の画像 1 Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 10、 3の画像 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: 手順 10、 3の画像 3
    • Pry the back plate off with a plastic opening tool
終わりに
作成者
2人の作成者と共同で作成されました。
Olivia A
メンバー登録日: 10/24/16
484 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017人のメンバー
UMASSD-JULIE-S17S7G3
4 メンバー
12のガイドは作成済み
コメント 1 件
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 391
