メインコンテンツにスキップ
Fujifilm FinePix XP70 Back Button Replacement
必要な工具と部品
  1. Fujifilm FinePix XP70 Back Button Replacement, Battery: 手順 1、 1の画像 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Back Button Replacement: 手順 2、 2の画像 1 Fujifilm FinePix XP70 Back Button Replacement: 手順 2、 2の画像 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Back Button Replacement: 手順 3、 1の画像 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Back Button Replacement, Button: 手順 4、 2の画像 1 Fujifilm FinePix XP70 Back Button Replacement, Button: 手順 4、 2の画像 2
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Back Button Replacement: 手順 5、 1の画像 1
    • Pull the three buttons out.
  6. Fujifilm FinePix XP70 Back Button Replacement, Front and Back Panel: 手順 6、 1の画像 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP70 Back Button Replacement: 手順 7、 1の画像 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP70 Back Button Replacement: 手順 8、 1の画像 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP70 Back Button Replacement: 手順 9、 1の画像 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP70 Back Button Replacement: 手順 10、 2の画像 1 Fujifilm FinePix XP70 Back Button Replacement: 手順 10、 2の画像 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP70 Back Button Replacement: 手順 11、 1の画像 1
    • Lift off the front plate.
  12. Fujifilm FinePix XP70 Back Button Replacement: 手順 12、 3の画像 1 Fujifilm FinePix XP70 Back Button Replacement: 手順 12、 3の画像 2 Fujifilm FinePix XP70 Back Button Replacement: 手順 12、 3の画像 3
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP70 Back Button Replacement, Back Panel: 手順 13、 1の画像 1
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP70 Back Button Replacement: 手順 14、 3の画像 1 Fujifilm FinePix XP70 Back Button Replacement: 手順 14、 3の画像 2 Fujifilm FinePix XP70 Back Button Replacement: 手順 14、 3の画像 3
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP70 Back Button Replacement: 手順 15、 1の画像 1
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP70 Back Button Replacement: 手順 16、 2の画像 1 Fujifilm FinePix XP70 Back Button Replacement: 手順 16、 2の画像 2
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP70 Back Button Replacement, Back Button: 手順 17、 1の画像 1
    • Lift of the metal panel using a plastic opening tool.
  18. Fujifilm FinePix XP70 Back Button Replacement: 手順 18、 1の画像 1
    • Remove the desired button(s).
    • Handle the buttons with care since they easily fall off.
終わりに
作成者
3人の作成者と共同で作成されました。
sandino santos
メンバー登録日: 03/22/17
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017人のメンバー
UMASSD-JULIE-S17S7G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 312
