メインコンテンツにスキップ
Fujifilm FinePix S9600 Camera Wont Power On
必要な工具と部品
  1. Fujifilm FinePix S9600 Camera Wont Power On, Fujifilm FinePix S9600 Camera Wont Power On: 手順 1、 1の画像 1
    • Start The Dissassembly
  2. Fujifilm FinePix S9600 Camera Wont Power On: 手順 2、 1の画像 1
    • Remove the command dial cover by pushing the cover upwards with your thumb just below the command dial. Then disconnect the ribbon cable and remove the cover completely.
  3. Fujifilm FinePix S9600 Camera Wont Power On: 手順 3、 3の画像 1 Fujifilm FinePix S9600 Camera Wont Power On: 手順 3、 3の画像 2 Fujifilm FinePix S9600 Camera Wont Power On: 手順 3、 3の画像 3
    • It was at this point i turned the camera upside down & heard something moving around inside and out came this micro switch.
    • It was then i had to figure out where it had come from. After a bit of investigating i figured out that it was the switch from the door flap of the memory card compartment.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
gazza667
メンバー登録日: 05/20/14
238 ポイント
1ガイドが承認済み
3 件のコメント
Thank you so for the info.
My neighbour just asked me if i could repair his old S5600.
Most likely, you just saved me A LOT of time and head scratching.
I will post the results in a few days.
Nilson Costa - 返信
I had the same problem so dismantled as instructions but nothing was loose or fell out. What else could it be
chrissytrev - 返信
Sorry it’s taken so long to reply, Have you checked the micro switch is working on the memory card door? If it is stuck in the open position then the camera won’t power on. You can usually tell if it works by pressing it in with the end of a pen or something. You should hear a noticeable click. If you don’t hear it then they are fragile & do sometimes stick.
Hope this helps.
gazza667 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 3,550
