はじめに
This is a guide for replacing the command dial on the Fujifilm FinePix S9500 camera. The command dial allows for the adjustment of shutter speed, and aperture. This guide will show you how to remove the case top, and the metal assembly connected to the command dial for the purpose of replacement.
必要な工具と部品
Locate and remove two screws. They are M1.7 x 5.0 in size.
The first screw is below and to the left of the command dial on the back of the camera.
The second screw is on the right side of the camera, to the right of the strap mount.
