メインコンテンツにスキップ
Fujifilm FinePix S9500 Command Dial Replacement
必要な工具と部品
  1. Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: 手順 1、 3の画像 1 Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: 手順 1、 3の画像 2 Fujifilm FinePix S9500 Command Dial Replacement, Fujifilm FinePix S9500 Case Top Removal: 手順 1、 3の画像 3
    • Locate and remove two screws. They are M1.7 x 5.0 in size.
    • The first screw is below and to the left of the command dial on the back of the camera.
    • The second screw is on the right side of the camera, to the right of the strap mount.
  2. Fujifilm FinePix S9500 Command Dial Replacement: 手順 2、 3の画像 1 Fujifilm FinePix S9500 Command Dial Replacement: 手順 2、 3の画像 2 Fujifilm FinePix S9500 Command Dial Replacement: 手順 2、 3の画像 3
    • To access the flash on the camera, locate the button on the left side and press it to open.
    • It's important to have the flash open to avoid any interference during disassembly.
  3. Fujifilm FinePix S9500 Command Dial Replacement: 手順 3、 3の画像 1 Fujifilm FinePix S9500 Command Dial Replacement: 手順 3、 3の画像 2 Fujifilm FinePix S9500 Command Dial Replacement: 手順 3、 3の画像 3
    • To open the case, gently push upward in the area just below the command dial with your thumb.
    • The top should pop up, but not fully detach.
    • To release the catch located on the left of the command dial and at the base of the flash, place your thumb to the right of the command dial and push upwards at a 45° angle towards the flash.
  4. Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: 手順 4、 3の画像 1 Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: 手順 4、 3の画像 2 Fujifilm FinePix S9500 Command Dial Replacement, Command Dial: 手順 4、 3の画像 3
    • Remove the four Phillips screws (M1.7 x 5.0) on the back of the metal bracket.
  5. Fujifilm FinePix S9500 Command Dial Replacement: 手順 5、 3の画像 1 Fujifilm FinePix S9500 Command Dial Replacement: 手順 5、 3の画像 2 Fujifilm FinePix S9500 Command Dial Replacement: 手順 5、 3の画像 3
    • Remove the metal assembly that has been released by the screws.
終わりに
作成者
2人の作成者と共同で作成されました。
Ben Stevens
メンバー登録日: 03/24/23
292 ポイント
3のガイドは作成済み
チーム
Casper College, Team 1-1, Lareau Spring 2023 Casper College, Team 1-1, Lareau Spring 2023人のメンバー
CASC-LAREAU-S23S1G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 18
今までの合計 202
