メインコンテンツにスキップ
Fujifilm FinePix S8200 LCD Screen Replacement
必要な工具と部品
  1. Fujifilm FinePix S8200 LCD Screen  Replacement, Batteries: 手順 1、 1の画像 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 2、 1の画像 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 3、 1の画像 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 手順 4、 3の画像 1 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 手順 4、 3の画像 2 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 手順 4、 3の画像 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 5、 3の画像 1 Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 5、 3の画像 2 Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 5、 3の画像 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 LCD Screen  Replacement: 手順 6、 1の画像 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 手順 7、 2の画像 1 Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 手順 7、 2の画像 2
    • Fold back the LCD screen with the plastic opening tool.
    • Remove the cable coming from the LCD screen that goes into the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Joseph Kelley
メンバー登録日: 01/15/15
228 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015人のメンバー
USFT-REMMELL-W15S7G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 1,295
