メインコンテンツにスキップ
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: 手順 1、 1の画像 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: 手順 2、 1の画像 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: 手順 3、 1の画像 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
終わりに
Insert your new batteries, close the battery chamber, and you're done!
作成者
1人の作成者と共同作成されました。
Greg Sweeney
メンバー登録日: 01/14/15
137 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015人のメンバー
USFT-REMMELL-W15S7G1
4 メンバー
9のガイドは作成済み
3 件のコメント
should there be an indicator led to show the camera is charing ?
tony smith - 返信
should the camera indicate that it is being charged ?
tony smith - 返信
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 1,753
