メインコンテンツにスキップ
Fujifilm FinePix S4800 LCD Screen Replacement
必要な工具と部品
  1. Fujifilm FinePix S4800 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 2、 3の画像 1 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 2、 3の画像 2 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 2、 3の画像 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 LCD Screen Replacement, Rear Case: 手順 3、 1の画像 1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 4、 1の画像 1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 5、 1の画像 1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 6、 3の画像 1 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 6、 3の画像 2 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 6、 3の画像 3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 7、 3の画像 1 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 7、 3の画像 2 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 7、 3の画像 3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 8、 2の画像 1 Fujifilm FinePix S4800 LCD Screen Replacement: 手順 8、 2の画像 2
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: 手順 9、 3の画像 1 Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: 手順 9、 3の画像 2 Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: 手順 9、 3の画像 3
    • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
    • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
    • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
  10. Fujifilm FinePix S4800 LCD Screen Replacement: 手順 10、 1の画像 1
    • Lift the screen away from the camera and set it aside.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Stephen Calabrese
メンバー登録日: 02/17/17
611 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017人のメンバー
USFT-HOFFMAN-S17S19G4
4 メンバー
16のガイドは作成済み
2件のガイドコメント
Thank you Stephen for this tutorial. I have two hobbies, photography and video games, especially in games, I am fascinated by music. I know that licensing music for developers is a long process, but thanks to a service like https://www.styngr.com/ music licensing for developers won't be a problem
Sean Foden - 返信
It's easy to agree that, it's very hard to find a reputable and trustworthy online casino. The only casino I can recommend is GG Bet promokod casino because people trust it. According to statistics https://crongdor.com/ this online casino has the highest RTP.
Дмитрий Куб - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 1,277
