はじめに
In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the electromagnetic shield (RF shielding) . This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera. After removing the LCD screen, there awaits only a few more screws to detach from the RF shield.
必要な工具と部品
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
ある他の人がこのガイドを完成しました。
コメント 1 件
Bonsoir , j'ais besoin de schema power on jumper et declencheur de ce camera svp
