メインコンテンツにスキップ
Fujifilm FinePix S4800 Battery Compartment Door Replacement
必要な工具と部品
  1. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery: 手順 1、 1の画像 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 2、 3の画像 1 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 2、 3の画像 2 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 2、 3の画像 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Rear Case: 手順 3、 1の画像 1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 4、 1の画像 1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 5、 1の画像 1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 6、 3の画像 1 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 6、 3の画像 2 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 6、 3の画像 3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 7、 3の画像 1 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 7、 3の画像 2 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 7、 3の画像 3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 8、 2の画像 1 Fujifilm FinePix S4800 Battery Compartment Door Replacement: 手順 8、 2の画像 2
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 手順 9、 3の画像 1 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 手順 9、 3の画像 2 Fujifilm FinePix S4800 Battery Compartment Door Replacement, Battery Compartment Door: 手順 9、 3の画像 3
    • Once the rear case is removed, gently separate the battery compartment door from its position.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Lairhe Barreto Paez
メンバー登録日: 02/17/17
285 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017人のメンバー
USFT-HOFFMAN-S17S19G4
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 52
今までの合計 2,430
